RCV axle comes with grease marked "external use only" ???
Got my new RCV axle/cv-joint set up today and just got done installing. Didn't come with instructions, but followed the write-up posted on this forum and it was pretty easy.
I do have one question. It came with a big tube of grease, which I assumed was for greasing the CV joints via the needle/zerks in the end of the axle. However, it says "EXTERNAL USE ONLY!" in big letters on the tube. What the heck does that mean?
-wwiifirearms
-wwiifirearms
that was to grease the shafts before you slide them in the axle tube, at least that's what I used it for since the cv joints were already greased. If I remember correctly, the instructions from RCV stated to grease the shafts. I only followed those instructions, so if I greased the shafts, then the instructions must have called for it.
The tube says " CV GREASE Formulated Exclusively for RCV Ultimate CV's".
I doubt they had special grease formulated for smearing on the axles during installation. I used plain old red bearing grease for that.
-wwiifirearms
-wwiifirearms
I guess I just had a hard time believing we have come to the point that we need to tell people not to stick CV grease inside their bodies. I thought they couldn't seriously feel the need to put that in large print, so I thought I must be missing something. Maybe in other parts of the country this is a big problem, but in the midwest I haven't seen a lot people eating or otherwise placing automotive grease in their bodies.
-wwiifirearms
-wwiifirearms
