tire size question
Old Mar 12, 2011 | 12:45 PM
rmoore851's Avatar
Default tire size question
What size bfgoodrich at/ko would be good on a stock unlimited with 17" wheels?
Old Mar 12, 2011 | 01:02 PM
ABQ_Dave's Avatar
If I'm not mistaken, 255/75 R17 are appropriate on a stock vehicle.Click image for larger version
Old Mar 12, 2011 | 01:10 PM
rmoore851's Avatar
Originally Posted by ABQ_Dave
If I'm not mistaken, 255/75 R17 are appropriate on a stock vehicle.Attachment 136784
Yes that is the stock size but the at/ko does not come in that size
Old Mar 12, 2011 | 01:12 PM
I had a 285/17/70 BFG TA KO..and it was fine...Great tires!
Old Mar 12, 2011 | 02:38 PM
Merlin4979's Avatar
If you go with a simple lift, like the Teraflex Leveling Kit (super easy to install, and only about $130), you can go as large as a 34" tire.
Old Mar 12, 2011 | 07:06 PM
mdnky's Avatar
285/70-17 with 1.5" wheel spacers in the AT KO (55lbs D, 59lbs E.) Other option is the BFG KM2 in 255/80-17 (no lift or spacers needed, slightly larger than the stock option @ 33.3", 54lbs E.) I prefer my KM2s over the AT KOs I've had in the past.
Old Mar 13, 2011 | 08:56 AM
coltc2000's Avatar
275/70/17 slightly wider a touch taller and no other stuff needed. AT KO available in this size.
Old Mar 13, 2011 | 09:38 AM
2saharas's Avatar
Depends on what you mean by "a good size...." Do they make a 295/70 r17? with spidertrax youd clear em....
