OME Lift Installed report and a question or two?
Old Mar 12, 2011 | 06:31 PM
pemberton's Avatar
Default OME Lift Installed report and a question or two?
Just finished the OME lift with heavy duty springs - wow!
This was advertised to deliver 2.5 - 3" of lift; but I just measured the height at the front and rear bumpers. The actual lift is 5.5" front, 5.5" rear.
This is much more than I expected - reports I have read indicated that a lift of 3.5 -4" was to be expected.
The measured change was my stock 2010 JK Sahara Unlimited after installing after market bumpers (Hyline w tire carrier rear bumper, Body Armor quad w/skid plate and Warren M8000 winch front). Both of these bumpers are fairly heavy.
Drives very nicely on the highway at 65 - 75 mph. In fact, I don't think it has any degradation to handling - it is not what I expected w HD springs - very civilized on road! No off road testing yet, but looks to be a real good upgrade, shocks feel solid.
New wheels and 35 Duratracks are next - which will bump it up another inch or so.
One or two problems - my ESP BAS light is now on and the steering wheel is off about 15 degrees. So I have some work to do. Any suggestions??
I will post some photos after my new wheels and tires come in!
Old Mar 12, 2011 | 06:38 PM
Robar's Avatar
This should help with the esp issues too.
Q: How do I recenter my steering wheel?
A: To re-center your steering wheel, use a 15mm wrench to loosen the 2 nuts on the turnbuckle on your drag link as shown in the pic below. Then, rotate the turnbuckle clockwise or counter clockwise as needed while a friend watches the steering wheel (or you periodically check on it yourself) go back to center. Once re-centered, secure the nuts and take it for a drive to check your steering wheel. This may take a few tries to get it on 100% but that’s all there is to it.
Old Mar 12, 2011 | 06:49 PM
nthinuf's Avatar
Which coils did you get? There are tags with the numbers on each coil. Sounds like you got the +40's?
Old Mar 12, 2011 | 07:04 PM
pemberton's Avatar
Originally Posted by ECHO
It will settle alittle for you maybe a 1/4" after some driving.. Post up some picutres so we can see... Sounds like you got some bang from your bucks inch wise.. Noticed you said you purchased the Heavy Duty springs.. did they give a height difference for the other springs
I don't have spring numbers, can look on the boxes. I simply measured the ground to bottom of the bumpers, fore and aft, before and after the lift.
Old Mar 12, 2011 | 07:28 PM
DougHeffernan's Avatar
I'm installing mine tmrw and I sure hope I don't get that much lift because I do not want to start changing driveshafts and whatever other problems associated with a 5 in lift.. This doesn't sound correct. I hate to ask but are you sure your measurements are correct?
Btw where did you buy your lift from?
Old Mar 12, 2011 | 07:44 PM
nthinuf's Avatar
With that height, it has to be the +40 coils.
https://www.jk-forum.com/forums/show...&highlight=ome
Old Mar 12, 2011 | 07:47 PM
+40's ?? Please explain.. I thought you only had choice between different load ranges..
Without going in shop to look I believe I have front part 2619 rear 2618 springs
Old Mar 12, 2011 | 07:50 PM
Sorry I asked for explanation before page refreshed. I don't believe I have those which is a good thing. Thanks for info
Old Mar 12, 2011 | 07:51 PM
Pluke the 2's Avatar
+40's are 4-5" coils made by OME.
OME has like 14 different coils.
Old Mar 12, 2011 | 07:56 PM
That tall a spring I'm sure they have alot of bowing ? I had to go check and I have shorter versions . But that is a nice height increase if that's what is wanted ..
