Doing stubby bumper next weekend...ADVICE???
Old Mar 13, 2011 | 08:31 PM
jeepguy553's Avatar
Default Doing stubby bumper next weekend...ADVICE???
Have SAWZALL WILL TRAVEL....
I did the search and saw all the posts. Is there a best way to do this thing? Masking tape and measuring tapes aside...let's get down to the nut cutting. I would rather not eff up a perfectly good front bumper when I could go and buy a bolt-up deal. This what Jeepin' is all about. DO IT YOURSELF!
So let's hear it. Stubby front bumper with a soon-to-be-built winch plate.
Old Mar 13, 2011 | 10:18 PM
ChopN's Avatar
Nut cutting? Dont recall having to do that. You'll only have to trim a few inches of the steel off depending on how stubby you want it. Are you going to put the ends back on? I used rivets but if I did it again I'd use a torch. I saw some pics and it looks good. And paint it while you got it off. Good luck!
Old Mar 14, 2011 | 06:33 AM
jeepguy553's Avatar
Fair enough.
Any ideas on a winch mount for the OEM front bumper? I bet the answer to that will be GET AN AFTERMARKET BUMPER..
Old Mar 14, 2011 | 07:34 AM
tj_2010jk's Avatar
For $60 You can get a stubby bumper kit that gives you caps that slide over the shortened ends. This is what I'll be doing, I like the "factory stubby" look.
Old Mar 14, 2011 | 07:48 AM
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
This might help you out.
http://project-jk.com/jeep-jk-write-...umper-write-up
As for the winch mount, Harbor freight used to have a winch plate.
Dont know if they still do or not.
Old Mar 14, 2011 | 11:13 AM
JK-UTE's Avatar
Just put added a winch this weekend to a stock front bumper. Used a harbor freight winch plate. Easy enough to do, especially if you are going to be "stubbifying"
your bumper...
Old Mar 14, 2011 | 11:36 AM
mrijeff's Avatar
Post some pics. I want to see that.
Old Mar 14, 2011 | 12:37 PM
Danny4652's Avatar
I used the plastic push in rivets from Lowes. They are holding up very well.
ID:	137901Click image for larger version
Old Mar 14, 2011 | 12:39 PM
Vincent's Avatar
your bumper...
Pics please I've been wanting to do the same too!!!
Old Mar 14, 2011 | 12:40 PM
jeepguy553's Avatar
@Danny4562...I like that light bar on your bumper. How did you do that? Was it something you ordered from the stealership?
And yes JK-UTE...it is ok to hijack this post with pics of your winch install on an OEM bumper. I want to see them too!
