3.5" Lift = What steering set up???
Is an adjustable front trackbar good enough for a 3.5" lift or will the un-road manners be much better with a draglink flip and axle mounted trackbar bracket?
I want to do it right the first time but I don't want to drop $300 on a flip kit if I would be perfectly happy with an adjustable trackbar.
I want to do it right the first time but I don't want to drop $300 on a flip kit if I would be perfectly happy with an adjustable track bar.
Good luck in whatever you decide! The front end was my nemesis LoL
Do it right 1 time
I have a TF 3" and was running JKS TB. Drove great then started getting bump steer worse and worse
Added front LCAs and made it better but still had bump steer
Added the AEV highsteer (drag link flip and TB bracket to raise TB) it drives amazing now night and day difference.
I would:
TB bracket
Drag link flip
Front LCAs
Adj trackbar
I would:
TB bracket
Drag link flip
Front LCAs
Adj trackbar
At 3.5, you'll be ok with just an adjustable. Over 4", drive it and see what you think, but you may end up with a flip.
I have a 3.5 and adjustable with a drop pitman arm and it does ok. I do get a little bump steer though.
Watch this vid and compare your angles
http://rides.webshots.com/video/3016...02496289IjoMUo
