285/70/17?
Old Mar 15, 2011 | 03:10 PM
XTHEKIDX's Avatar
Default 285/70/17?
Was wondering if I could go 285/70/17s without having to upgrade ball joints, tie rods, etc:
Old Mar 15, 2011 | 05:30 PM
RA032726's Avatar
Banned Member
Are you planning you mount them on stock rims or custom rims? If custom rims what rim width and offset or backspacing are you going to get? I'm looking at the same tire size.
Old Mar 15, 2011 | 05:43 PM
RA032726's Avatar
Banned Member
Originally Posted by ECHO
You want your backspacing to be between 3.75 & 4.75.. Most aftermarket wheels are available in 4.5" BS.. If you keep the Stock wheels which are 6.25" BS .. get 1.5" wheels spacers and that will change your BS to 4.75.. which for that size tire will keep them from rubbing at articulation or full turns
You are right of course, I was just hoping rubbing would not be an issue but suspected it would be.
Old Mar 15, 2011 | 07:01 PM
XTHEKIDX's Avatar
Yeah I am going with the Pro Comp 7005s, figured it would wear em down a bit quicker, good to know that they don't need to be replaced just yet though.
