can someone measure there 285/70/17 duratracs?
Old Mar 15, 2011 | 11:28 PM
wiesmanr's Avatar
Default can someone measure there 285/70/17 duratracs?
just wondering if someone could measure their mounted 285/70/17 duratracs on there unlimited. I am wondering the height difference between them and my stock 255/75/17. not sure if I want the 265's or 285's. I want to stay as close to the stock height as possible. also if someone could measure their 265 duratracs.
Thanks
Old Mar 15, 2011 | 11:51 PM
ezav8tr's Avatar
Vet Army
good question.
Old Mar 16, 2011 | 01:14 AM
DougHeffernan's Avatar
Thanks
Try this site to calculate tire height
http://www.1010tires.com/tiresizecalculator.asp
Or if you have an iPhone use this free app
http://itunes.apple.com/us/app/tires/id314543818?mt=8
Old Mar 16, 2011 | 01:43 AM
ezav8tr's Avatar
Vet Army
Does it give the actual/true size as they sit on a vehicle at the recommended air pressure?
Old Mar 16, 2011 | 02:10 AM
No it doesn't .. Just diameter of tire
Old Mar 16, 2011 | 02:25 AM
rbaldinellii's Avatar
Go under SPECS and it gives you all the information your looking for.
http://www.tirerack.com/tires/tires....omCompare1=yes
Old Mar 16, 2011 | 09:41 AM
wiesmanr's Avatar
thanks for the help, but I am looking to the actual measurements on the vehicle, not what is listed by the manufacturer.
Old Mar 16, 2011 | 10:24 AM
Discount Tire's Avatar
Sponsoring Vendor
I use this, its should be close enough for an estimation: http://www.discounttiredirect.com/di...foTireMath.jsp
Old Mar 16, 2011 | 10:30 AM
Rafi's Avatar
I have 315/70/17 duratracs. my mounted on vehicle measured height is ~1" lower than the specs that GY says.
I bet it would be very close to the same on the size you are looking at. So 32's?
Old Mar 16, 2011 | 11:22 AM
WhiskyPirate's Avatar
When I recalibrated my speedo with my Flashpaq for my 33's, it takes actual tire size. My Duratracs measured in at 31.75" w/ ~ 35psi and speedo checked dead on.
