RK front spring clips
Has anyone installed a pair of these on their JK yet?
Got mine yesterday and no instructions came with them. Can someone direct me in installing these.
Thank you.
Thank you.
I have the Currie rear so I only need info on the RK front clips. I'm at work and just thinking about it. It onlly comes with the clip and two bolts and nuts. I want to know if I have to drill for the bolts or if there is already a mounting spot?
From our friends at Rock Krawler:
If you can give us an email address we will send you out the instructions. They should have been in your 2.5" MT instructions as well since they are included in the 3.5" X Factor Kit...
RK
RK
I installed my spring clip retainers last year. No instructions so I just installed them to what made sense to me. I drilled a hole in the corner of the spring perch and installed with the provided hardware.
You can see the clip beyond the TB bracket holding down the spring lower coil.
