superior rear shafts
Old Sep 29, 2007 | 06:59 AM
blueox's Avatar
Default superior rear shafts
Has anyone put these 32 spline alloy shafts in their truck? If so did the abs tone gear press off the factory axle and fit the superiors? I pre pressed the superiors with retaining bracket, seal, bearing and collar. Then when I was ready to swap axles I crapped when I saw the abs gear. I dont really want to lose the ABS functions, so hopefully the gears can be swapped. JP
