Dana 44 fluid capacity with ARB diff covers help
Old Mar 17, 2011 | 09:32 AM
shockwaveaz's Avatar
Default Dana 44 fluid with ARB diff covers..how much?
Good day my fellow Jeepers,
I read on WOL's write up, which included the following capacities:
2.375 quarts - Rear
1.35 quarts – Front
Are the above listed fluid capacities for both the Dana 44 front and rear differentials? Based on my initial impression, there seems to be a big difference in fluid levels in respect to the front vs the rear differential. I wanted to be sure, as it could be a costly mistake.
As always,
Thanks
Old Mar 17, 2011 | 09:55 AM
sa29560's Avatar
If you do end up with too much in it the excess will come out of the breather tube.
Capacity actually lowers with that particular cover, correct???
Old Mar 17, 2011 | 03:57 PM
Bump to the top
Old Mar 17, 2011 | 04:10 PM
Olean NY Jeeper's Avatar
I just changed my rear diff fluid and I have ARB cover and locker. I put in 2.5 quarts. Diff hasnt puked so i think it was good amount. I rotated my pinion up for new DS so I wanted to put a little extra bacause of that.
Old Mar 17, 2011 | 04:11 PM
Cool, Thanks.
How about the front?
Old Mar 17, 2011 | 04:15 PM
Originally Posted by shockwaveaz
Cool, Thanks.
Havent done the front yet. I just changed fluid after regear, installer told me to change back at 500 and front at 1000 miles since the front doesnt get as much use. I have a dana 30 up front, I have no ide how much to put in for that
Old Mar 17, 2011 | 04:18 PM
Thanks for the reply, I have a 44 up front and wanted to get the fluid changed but dont want to put too little or make a mess with too much
Old Mar 18, 2011 | 05:37 PM
When you do the front, let me know how much u put in and if u have problems.
Old Mar 18, 2011 | 05:54 PM
mkjeep's Avatar
Front takes less because there is no gear oil running into the axle tubes to lubricate bearings at the far end of the axle in the front. You have a u-joint and a unit bearing/hub. The rear lubes the bearings at the rear axle flange. The front bearings/seals are at the pumpkin.
Old Mar 18, 2011 | 08:41 PM
That makes perfect sense!
Thanks for the reply and lesson.
I used the amount of oil from the writeup, no noise... seems just fine.
Sent from my PC36100 using Tapatalk
