Any issues with a TF 2.5 coil lift and 2 inch spacer?
We just finished installing the TF 2.5 inch coil lift, TF shocks and TF LCA and we used the 2 inch spacers from the BB that was originally on the 08 JK 4dr. With the Garvin roof rack the JK as .5 inches of clearance thru the garage door...
Has anyone done the 2.5 inch coil lift with 2 inch spacer? Are there any issues with doing this?
thanks
Doug
I will post pics tomorrow.
thanks
Doug
I will take some pictures with the 4.5 inch lift.
Based on my readings about the issues with the drive shaft angle I will probably take the 2 inch spacers out.
thanks
Doug
thanks
Doug
Please take some pics now with the spacers in. I'm looking at installing 1.75 spacers on my front 2.5 TF coils. I'm going to go with the AEV brackets $109.00 to bring my castor back to "some" reasonable level. If I don't like it I can go to 1" spacer. or 3" TF coils up front which are another 1" taller then our 2.5 coils.... Either way I'm going up for sure.
I'm also getting the OME LT shocks when I go this route. Brake line extensions, and most likely sway bar links.
The AEV bracket is useable in my application. From the front axle spring pearch to the frame is six inches now, After the spacer install I'll be at 7.75 inches. You can "use" the bracket between 7-9 inches. I can "not" recommend this to anyone else until I try it myself.
There are better ways to do it as mentioned above from planman
