Doing fender flares mode - cutting it, got few questions
Old Mar 18, 2011 | 03:27 PM
SFBayArea's Avatar
Default Doing fender flares mode - cutting it, got few questions
Hey guys, I decided to cut my fender flares. I just did one side - driver side. But I have a question, what do you do with the turn signal blinker, do you relocate it somewhere somehow?
Also, if I see it correctly, there are two piece underline one is more of flimsy plastic that attached via plastic tree and another one is more stirdy one that attached via bolts/nuts. Do you cut both of them?
Old Mar 18, 2011 | 03:33 PM
SFBayArea's Avatar
Here is the picture of the fender flare with the more rigid liner still attached to it. I'd like to keep that liner on, but what do you do with those overhanging brackets? Do you simply cut them off?
Old Mar 18, 2011 | 03:35 PM
PainKiller's Avatar
here is what I did for the marker light after I cut my fenders
https://www.jk-forum.com/forums/show...p+marker+light
and If you are talking about the thin inner fenders, You need to remove them and do a few small cuts here and there . try reds write up here ::
Old Mar 18, 2011 | 05:56 PM
SFBayArea's Avatar
Did front today, will leave rear for tomorrow. So far like it.
Old Mar 18, 2011 | 06:07 PM
renpia's Avatar
I just reused the stock marker lights and zip tied it to the body panel. There's a spot that it tucks into.
Old Mar 18, 2011 | 06:14 PM
SFBayArea's Avatar
renpia, do you have a close up picture of how you did it and where you ziptied it to? I really like it.
