Tire size question
Old Mar 19, 2011 | 11:57 PM
jmac-2's Avatar
Default Tire size question
Can I run 305/70/16 on a wheel with 4.5 back spacing?
I do not have a lift.....
Old Mar 20, 2011 | 12:49 AM
jonboy's Avatar
Yes you can but you will have some rubbing at full lock
Old Mar 20, 2011 | 12:14 PM
Winston's Avatar
What if he had a 2.5 lift and it is a 4 door..?
Old Mar 20, 2011 | 12:33 PM
jonboy's Avatar
My wifes jku has rough country 3.5 lift with 305/70/16 on 16x8 4.5 bs and the tires rub on the lca @ full lock.
Old Mar 20, 2011 | 02:16 PM
jmac-2's Avatar
Wow, so it sounds like I will have some rubbing issues even with a small lift then....
Old Mar 20, 2011 | 02:29 PM
Dralphy's Avatar
I think it depends really. People on here rub with a 2.5 inch lift, and some don't. Depends on what kind of wheeling you would be doing.
Old Mar 20, 2011 | 03:41 PM
jonboy's Avatar
Dis-reguard my last post I went out to change the oil in the wifes jeep and I noticed that I installed the lca backwards. I know it was a dipsh*t move but I did it that's all I can say bout that. However after I turns it around there's no more rub @ full lock... so you maybe fine after all. Sorry if I mislead you.
Old Mar 21, 2011 | 11:20 AM
jmac-2's Avatar
Ok, So then I could likely run the 305's with little or no rubbing without the lift...and likely none at all with a small lift?
Old Mar 21, 2011 | 12:12 PM
jonboy's Avatar
You should be fine, my wife drove hers w/o lift for 3 days but it was all highway and city driving, no off road to speak of
Old Mar 21, 2011 | 09:38 PM
jmac-2's Avatar
Ok, I appreciate the feedback!
