Unlimiteds with TF 4": rear driveshaft?
Old Mar 20, 2011 | 10:52 AM
m(a)ce's Avatar
Default Unlimiteds with TF 4": rear driveshaft?
did you have to replace your rear driveshaft after putting a TF 4" on your unlimited?
is it necessary/recommended? how long did your stocker last?
Old Mar 20, 2011 | 10:57 AM
McPuck86's Avatar
Replace it with the lift. The stock will be too short, I think.
Old Mar 20, 2011 | 11:05 AM
Harbourone's Avatar
I'm running 4.5 total lift now on stock shafts. No vibrations at all.
Old Mar 20, 2011 | 11:09 AM
cfr's Avatar
cfr
Running the same lift and shock shafts. Tore the boot on the front shaft the first time I disconnected the swaybar links to run Fins & Things in Moab.
Old Mar 20, 2011 | 04:16 PM
m(a)ce's Avatar
thanks guys. anyone else?
Old Mar 20, 2011 | 04:22 PM
wiredawg_mg's Avatar
My rear shaft lasted for almost 2 years, It was broke on the trail and the lift wasn't a issue. On the Unlimited you should be good on the back for a while. That shaft is very long. You can save your funds for the time.
Now the front was dead in 9 months. So be prepared to do that one 1st.
Old Mar 20, 2011 | 04:56 PM
Birdog3's Avatar
i have the tf 4" flex arm kit im running the stock shafts, ill upgrade soon no vibrations.
Old Mar 20, 2011 | 05:29 PM
jeepguy553's Avatar
The CV joint and boot in my front D/S broke within months of putting my 4.5" lift on. Dealer replaced it under warranty. The lift has been on now for about 2 years and I haven't had any problems at all out of the rear D/S.
Old Mar 20, 2011 | 06:22 PM
mkjeep's Avatar
My stock rear lasted for over 2yrs on BB, then 4in superlift, then 4in TF, then bit the dust in a wreck.
Front shaft lasted about a year.
Old Mar 21, 2011 | 11:09 AM
m(a)ce's Avatar
thanks again for all the info & personal experiences.
