grease spill from my RCV
Look at the picture, it seems that there is some grease that stay on the ball when wheels are turn and throw grease all around, do you have a clue about that??
I put it on with the grease that is on it when you send it, not even add since install. Is it something you have experience? I will put the other one (driver side) tomorrow as the shaft is stuck to the bearing when I first try to install it (rust sucks down here!!!).
Did you ever get the other side installed??
yes, last times I check under the jeep, it's been a week after install and it have little grease that have escape so I'm not very concern about that. Will clean it when the weather get warmer, maybe this week when doing my oil change.
Nice feature from the rcv, no more steering wave when turning on hard ground, need to be tested on trail, maybe this month as the snow clear out
