trying to get larger tires and installers won't put on
Old Mar 24, 2011 | 01:30 PM
markpit's Avatar
Default trying to get larger tires and installers won't put on
tried getting larger tires installed , just 285/70/17 and the tire dealer would not put them on because they were larger then the oem ones which are 255/75/17. said that check engine light, abs sytem, esp would be affected is this truly a problem or not. I know it will mess up the mph. thanks
Old Mar 24, 2011 | 01:36 PM
Torrin's Avatar
Ummm, no it will not cause any of those problems (except the speedo)
Old Mar 24, 2011 | 02:51 PM
dsp's Avatar
dsp
Go to discount tire. no hassle.
Old Mar 24, 2011 | 02:56 PM
hate_1_monger's Avatar
you definitely need a new tire shop. Maybe find a local mom n pop place that will give you good service and no lip. Shop local and keep the money there as well.
Old Mar 24, 2011 | 02:59 PM
chazzmania's Avatar
x2 on discount tire.
Actually, last time was there they asked me when I was going to get bigger tires!
Soon, my jeep... sooon
Old Mar 24, 2011 | 04:16 PM
nangulator's Avatar
Originally Posted by ECHO
Or find a local privately owned garage that will do them..
X2, I mounted a set of 44s on a set of wheels at my shop, I have no idea what kind of vehicle they where going on
Old Mar 24, 2011 | 05:54 PM
mkjeep's Avatar
Go to a different shop, buy new ones, then take it by their shop and show them the $$$ and customer they just lost.
Old Mar 24, 2011 | 06:03 PM
Goeagles88's Avatar
I brought mine to firestone complete care. They did a great job and charged me $75 to mount and balance all 5.
Old Mar 24, 2011 | 06:39 PM
nmwranglerx's Avatar
This tire shop wouldn't happen to be Cosco, would it? They won't put anything on a jeep unless it's OEM specs which means that they wouldn't put anything larger than 225/75/16 on my X. So, I went to discount tire and they had no problem whatsoever putting 35s on. I had even bought the 35s second hand from CL. Interestingly, Costco did not have a problem mounting 35 on the spare rim that I brought them My advice is to try discount tire if you have a shop in your area or just take the wheels in.
Old Mar 24, 2011 | 06:41 PM
joe002's Avatar
I use/like Discount too, but don't bother going there if you have spacers.
