What kind of lift do I have?
Old Mar 28, 2011 | 07:15 PM
mdrobbins's Avatar
Default What kind of lift do I have?
Ok, so I'm feeling a little emasculated by this but I've given up. I bought this jeep used with about 31,000 miles on it and it is my intro into the jeep world. I have already been off-road at Bridgeport this past weekend and I'm in love. I want to know everything about this thing and I just can figure this out. I know its lifted because it stands taller than a stock rubi. Its a 2008 Sahara and here are all the pictures I took to try and help. Thanks
The steering stabilizers are Trail Masters SSv and the exposed piston is about 5"(don't know if that helps)
i'm pretty sure the springs are stock cause the number matches up with some other stock wranglers I've seen plus they are dull and washed out
The floor to the bend in the fender is about 38"
The tire size is 285/70/17
Thanks again for all the help!
ID:	143142   Click image for larger version
ID:	143144   Click image for larger version
ID:	143145   Click image for larger version
ID:	143146   Click image for larger version
Old Mar 28, 2011 | 07:36 PM
mdrobbins's Avatar
You have a trailmaster ssv lift
I'm sorry I should have been more specific.
I want to know what type of lift it is (body or suspension)
and mainly what size. thanks
Old Mar 28, 2011 | 07:38 PM
u-joint's Avatar
It's a suspension lift, more specifically a budget boost. You can see the polyurethane pucks on top of your coils in the one picture.
Old Mar 28, 2011 | 07:40 PM
mdrobbins's Avatar
So the size of the puck is the size of the lift?
Old Mar 28, 2011 | 07:41 PM
nthinuf's Avatar
JEEP WRANGLER (JK) - 2 & 4 DOOR - W/ SSV SHOCKS
Application: Jeep
Year: 2007 - 2010
Lift: 3"
Old Mar 28, 2011 | 07:43 PM
u-joint's Avatar
That is correct.
Old Mar 28, 2011 | 07:46 PM
mdrobbins's Avatar
Thanks everyone. I am looking to put some sway bar quick disconnects and I needed to know for sure what size lift I have. Thanks again!
