teraflex 3" suspension lift with 8 flex arms
Old Mar 28, 2011 | 07:51 PM
redcoals's Avatar
Default teraflex 3" suspension lift with 8 flex arms
Hi again,
does anyone know how to pull the front axle further back (don't know if it is possible) with the teraflex 3" suspension. I'm having a problem with the front sway bar disconnect on the passenger side where it is too close to the coil springs and need some help with adjustments. currently i live in a remote area about an hour from the shop and due to work i can't make it there often, so i'd like to try and fix it if possible by myself. The sway bar disconnect on the passenger side at times will bang off the coil. Maybe this is an manufacture error with teraflex (but i doubt it). Can i adjust my flex arms to pull back the front axle (not much is needed, i'd say about 1/4 inch would be good).
Thanks everyone.
Rob
Old Mar 29, 2011 | 01:11 AM
KING-JOUST's Avatar
I think you can probably just re-adujst the flex arms. I just put a TF 4"flex kit and they were adjustable. You may needa take it to an alignment shop and im sure they can do it so you wont effect your camber or toe. I know what you mean about work...I've been trying to take mine in for two weeks now. Only have one day off. Good luck.
Old Mar 29, 2011 | 06:43 AM
redcoals's Avatar
Thanks, I was thinking the same thing this morning when i woke up. Good luck with your 4", should have gone that route in hind sight.
Old Mar 29, 2011 | 06:35 PM
highwayman's Avatar
Sounds like the axle isnt centered, unless Im missing something. Did you confirm w/measurements?
