RE-GEAR Complete, Have a few Question??????
Old Mar 30, 2011 | 04:05 PM
kellyII's Avatar
Default RE-GEAR Complete, Have a few Question??????
well today I got my JK back from the shop after my 4.88 regear, the problem I have is that on my dash the ALB light, ESP Light and Traction control light are on, Is this common and is there a fix for it????? If it is as simple as pulling the ALB fuse I dont mind dong that
Old Mar 30, 2011 | 04:08 PM
Robar's Avatar
I don't think you should have any lights on if the install was done correctly.
Old Mar 30, 2011 | 04:12 PM
tslewisz's Avatar
No lights after my re-gear. My guess is that there is an ABS sensor dicked up disconnected.
Old Mar 30, 2011 | 04:13 PM
PainKiller's Avatar
those lights shouldn't be on. maybe do an inspection to see if something wasn't reconnected
Old Mar 30, 2011 | 04:46 PM
kellyII's Avatar
i checked all 4 wheels to see if the abs was all connected and they were.... I dont know what the crap it is. I didnt have this problem last time, and its the same installer. Guess I will stop in and see him tomorrow
Old Mar 30, 2011 | 04:58 PM
kellyII's Avatar
my brakes are working fine and they are not wanting to lock up. when I put it in 4wd and 4wd lo, it displayed on my dash (traction control off) UGH!!!
Old Mar 30, 2011 | 05:30 PM
Bosox5's Avatar
Veteran: Coast Guard
they may have busted an abs sensor taking your axles off, mine were rusted to hell when they pulled the axles.
Old Mar 30, 2011 | 06:03 PM
chknkatsu's Avatar
when you put it in 4lo it's supposed to be off...
Old Mar 30, 2011 | 06:26 PM
bigT's Avatar
When in 4Lo traction control turns off automaticly Sorry didnt see the above post yett!! GOOD LUCK!!
Old Mar 30, 2011 | 09:15 PM
slowpoke13's Avatar
shop put 5.13s on mine and there are no physical indications anything was ever done. No unheard of lights or warnings.
