what am i looking for?
Old Oct 2, 2007 | 07:51 AM
Krypler's Avatar
Default what am i looking for?
ok guys I lifted my 07 jeep 4 door 4in with superlift. I am still running stock tires and wheels. What do i need to be looking for as problems? i dont really fell much difference in the jeep. Just it kinda sways alittle bit but isnt that expected in the lift? and this morning when i backed out of garage and hit my break there was a loud pop sound mike the spring was popping or something when it came to a stop. the ESP isnt going off or anthing. I have recentered my stering wheel so thats good. just what else do i need to look out for so i can get it fixed before i get the 35in tires and wheels put on? Just trying to get the kinks out before thanks in advance
Old Oct 2, 2007 | 11:46 AM
Krypler's Avatar
I am taking it no one knows what i need to look for?
Old Oct 2, 2007 | 12:00 PM
medbender's Avatar
i'd check and make sure the sway you feel isnt from too little caster on the front angle which should be 5~7 degrees
Old Oct 2, 2007 | 12:03 PM
wayoflife's Avatar
JK-Forum Founder
A loud popping sound when braking could be something shifting. Are you sure that you tightened everything to the appropriate torque settings?
Old Oct 2, 2007 | 12:52 PM
bcperry2000's Avatar
yeah, i would just double check everything and make sure everything is tight. where abouts in dallas are you?
Old Oct 2, 2007 | 01:55 PM
00pumpkin's Avatar
Id check the trac bar's, especially the rear re-location bracket..........
Old Oct 2, 2007 | 06:15 PM
Krypler's Avatar
i am near dallas actually greenville just east of dallas i will be re checking the specs on the bolts. I heard more poping today when i was moving slowly and turn the wheel trying to park and then again when i was backing out of the parking spot.
Old Oct 2, 2007 | 11:33 PM
wayoflife's Avatar
JK-Forum Founder
Okay, are you still running the factory air dam? If so, your tire lugs are probably rubbing against them.
Old Oct 4, 2007 | 05:39 AM
Krypler's Avatar
ok guys i still have that popping sound even after i check the torque and i put on my 35s do you think i might be the spring still seating or does it ahve to do with the D bolts in the control arms? It only does t when im slowing doen or turning real slow.
Old Oct 4, 2007 | 05:44 AM
wayoflife's Avatar
JK-Forum Founder
Hmmmm, is it just like a "pop......... pop......... pop" or is it more like a "pop-pop-pop-pop" or just a single pop? Also, do you have an automatic? If so, have you checked to see how close your front drive shaft plastic boot is to the skid plate?
