What tools and sockets do I need to change out front axle on JK dana 30?
Old Mar 30, 2011 | 05:35 PM
Olean NY Jeeper's Avatar
Default What tools and sockets do I need to change out front axle on JK dana 30?
What tools and sockets do I need to change out front axle shafts on JK dana 30?
Going to wheeling trip next week, have spare shafts, what tools do I need and what sockets do I need to do the entire job if need be?
Old Mar 30, 2011 | 06:00 PM
KenB1010's Avatar
I believe that the procedure and the tools needed are the same between the D30 and the D44. Obviously the axles are going to be different.
Hope this helps.
https://www.jk-forum.com/forums/show...hlight=install
mkjeep's Avatar
Originally Posted by TheDirtman
21 mm for the calipers, 5 mm for the abs sensor, 35mm for the axle nut. 13 mm 12 point socket for the bearing bolts, make sure it is a 12 point and not 6 they are a bit tough to get to. You can use a 1 5/16" socket for the axle nut also. A big breaker bar is also recommended.
for the op The 5mm is an allen wrench btw
Old Mar 30, 2011 | 06:11 PM
mkjeep's Avatar
oops, sorry about that should have stated 5mm allen wrench for the abs. I just went out and confirmed the 21 mm on the calipers. I have rubi axles but the brakes are the same as the 30's
Thats alright, Ken posted his write-up anyway.
Old Mar 31, 2011 | 10:56 PM
Thanks guys, that exaclty what I needed, just want to make sure I dont start this job and dont have the right tools. Hopefully I wont need it but wheelig 6 hours away from home with no tow rig and u got to be preapred.
