Custom Flares
Old Mar 31, 2011 | 12:13 PM
SmileyWar's Avatar
Default Custom Flares
I`m planning to build my own flares.
At the moment with my new tyres they are sticking 26 cm out from the JK`s side panel. So i`m intending to use brackets to bolt on towards the original holes where the old flare is hanging from. And using 2 mm aluminium tread plate.
My question is if anybody can say that it is thick enough to use 2mm aluminium?
Each flare has 10 heavy duty support brackets.
Thanks for the responses in advance.
Btw i`m new here, and super happy to be a Wrangler Owner.
Old Mar 31, 2011 | 12:42 PM
sacdaddy03's Avatar
Here is some custom flares Borrowed it from COP
Old Mar 31, 2011 | 12:44 PM
09GRNJK's Avatar
^ Interesting
Old Mar 31, 2011 | 12:45 PM
Jeremy072288's Avatar
Wow those tires are freaking huge! Haha
Old Mar 31, 2011 | 02:33 PM
SmileyWar's Avatar
wow, thats maniak. I like it.
Nice mod on the Jeep
Old Mar 31, 2011 | 03:44 PM
renpia's Avatar
Originally Posted by ludski
if you air those bad boys down, the frame will scrape on the ground. bahaha.
I've seen a vid of this Jeep. It's on hydrolics and can go up and down to any height.
Old Mar 31, 2011 | 07:21 PM
D_engel's Avatar
I think that thing gets about 7 feet of suspension travel
Old Apr 12, 2011 | 11:41 AM
SmileyWar's Avatar
So i build these plastic ones, which was created for a quick fix to make it legal to drive.
Then i ripped the nasty plastic ones off, and cut and bolted the brackets on
And here is the finished first fase.
Still todo
- round up the two corners
- add more bolts on top of the plate.
- add two more brackets at the front, i could not bend it by hand so will have to do that at work
- Then i have a dilemma to either leave it aluminium color or change it to black.
i`m thinking black.
- Final touch is to add Edge Trim to make it look finished.
These are the jobs for the next days as i only have two hours of daylight a day after work.
Finished this first stage in two hours
Old Apr 12, 2011 | 11:44 AM
SmileyWar's Avatar
Btw i have no experience in modding a car, or anything todo with cars for that matter, so crits and suggestions are always welcome.
Or tips regarding my crazy adventure
Old Apr 12, 2011 | 12:14 PM
jpaustin87's Avatar
I like the originality man, and so far looks decent. I would definitely paint those bad boys though JMO, im not of fan of shiny stuff. Maybe use some bedliner if you do. Ill definitely subscribe to the thread this is interesting.
