tire size
Old Apr 28, 2011 | 10:46 AM
tomed13's Avatar
Default tire size
Whats the biggest tire i can fit on stock wheels and NO spacer?
Btw I have a 2" lift.
Old Apr 28, 2011 | 10:58 AM
09SDunlimited's Avatar
My jk came with the stock 16's. I fit a 285/75 r 16 on them but the tire felt sloppy and rubed the CA, the plastic air dam (quickly removed in reverse), and the rears rubbed the inside wheel well flexed, so I switched to a wider wheel. The size depends on what wheels your jk has from the factory. 285/75 on a stock rubi wheel probably would work fine.
Old Apr 28, 2011 | 11:18 AM
tomed13's Avatar
mine came with 17"
Old Apr 28, 2011 | 11:37 AM
Inko's Avatar
Im running 285/70 17's on stock rims and no spacers. I have 4 door coils in and I have no rubbing so you with a 2 inch lift should be fine. You could probably even run a 285/75 but not many companies make that size besides toyo.
Old Apr 28, 2011 | 11:44 AM
DownhomeMoto's Avatar
Need more info, what wheels do you have?
