tom woods ds question
Old Apr 28, 2011 | 03:10 PM
Kevo's Avatar
Default tom woods ds question
i just installed the ds from tom wood,i followed the directions in the write up on the coast and also used the youtube video,i have no vibrations but i do now have a odd rubbing noise that get louder the faster you go,the ds is not touching anything at all,anyone have any ideas on what could cause this
Old Apr 28, 2011 | 05:14 PM
Kevo's Avatar
Originally Posted by Youri
Are you sure you left off both of the dust shields off the yokes? I didn't the first time and it made grinding noises, sounded horrible.
I didn't on the front so i removed it and it still does it, I can't figure it out, it almost sounds like the caliper is stuck squeezing the rotor, is it possible I torques the pinion bolt too much
Old Apr 29, 2011 | 03:09 PM
Kevo's Avatar
I'm not an expert but I don't believe that torquing the pinion bolt too much will immediately cause damage, rather it will cause it to go out over time.
I'd jack up the jeep and try to see where the noise is coming from as someone spins the wheels.
okay i tore it back down and the crush sleeve was shot,i had to replace it
Old Apr 29, 2011 | 03:10 PM
Kevo's Avatar
thanks youri for taking the time to offer your opinion
Old Apr 29, 2011 | 06:41 PM
Alf1096's Avatar
What did you use to torque it down with I thought the crush sleeve took a lot of pressure to get it to crush. Did it wear out or did you over torque.
Old Apr 29, 2011 | 10:44 PM
Kevo's Avatar
I over torque it with a Mac air gun, I didn't mean to I put a torque wrench to it and couldn't budge the nut, this causes the lash to be to tight
Old Apr 29, 2011 | 10:45 PM
Kevo's Avatar
That sux. Was it easy to replace the crush sleeve?!
It wasn't bad, finding one was a pia
Old Apr 30, 2011 | 11:57 AM
josh_jacklyn's Avatar
did you instal the front or rear ds and how long of an instal was it? i'm thinking this might be my next upgrade as i just tore my front ds boot of last week in moab. i know alot of people say that ride around with a tore boot for years, all you have to do is grease it every now and then and just rinse the dirt off. but, i would feel better knowing that i wouldn't have to keep that in the back of my mind, if i just replaced it with a nice new shiny toms woods ds
Old Apr 30, 2011 | 12:31 PM
Kevo's Avatar
i did the fron and it was very simple hour job i just tried to get to far with the air gun before i used the torque wrench,so i suggest if you do it on a lift have someone hold the brakes
Old May 1, 2011 | 09:38 AM
cool thanks alot for the info. do you plan on doing the rear anytime soon? or are you going to keep the front for now?
