installing side steps?
May be a dumb question but when putting side steps on why wont the frame bolt come all the way out and when it does I would think the washer needs to come off but it don't seem to fit over bolt threads? Need help!!! Thanks
The washer is part of the bolt, it does not come off. The bolts should come out of the step bracket, You might have to remove the whole step before it comes out. I know when I install mine for the winter I have problems with 1 of the bolts, and it goes on first and off last otherwise it doesn't come out. Maybe the same with you?
There is a tab that has a threaded nut attached to it. It slides in that hole and fasten to the sheet metal. I sold my Sahara steps to a guy with a 2011 and he didn't have those on his from the factory. He was going to have to get some because I couldn't get mine off of my 2007.
Quadra has the install docs on their site. The diagrams should help you out.
2door
http://www.quadratec.com/products/12560_00.htm
4door
http://www.quadratec.com/products/12560_01_07.htm
2door
4door
2door
4door
2door
4door
