What wheel spacer?
Old May 4, 2011 | 05:51 AM
grayandashleyunlimited's Avatar
Default What wheel spacer?
What wheel spacer should I use, I have a 2011 2dr and I have the 16 inch steel wheels. Not enough cash to get new rims on top of the lift and tires. What is the best/cheapest way to go?
Old May 4, 2011 | 06:05 AM
wayoflife's Avatar
JK-Forum Founder
i have always run spidertrax spacers over the last 10 years on various jeeps and never had any problems with them. i would recommend getting 1.5" spacers too.
Old May 4, 2011 | 06:23 AM
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
FWIW, whatever you get, make sure they have grade 8 bolts and made out of 6061T6 Aluminum.
Spidertracks fit this perfectly.
FWIW, Northridge carries them.
Check the For Sale section. There is always someone looking to sell some.
Hope this helps.
Old May 4, 2011 | 01:34 PM
wittys-jk's Avatar
Spidertrax for sure! I love mine
Old May 4, 2011 | 01:48 PM
mefly2's Avatar
Gray-
Your message inbox is full ...
Please send tracking information on F/T bags; nothing has shown up here on this end ... with regard to the freedom top panel bags. TIA
Old May 5, 2011 | 09:09 AM
Thanks for the info. I will be looking around for some spidertrax.
Old May 5, 2011 | 09:15 AM
BKGM Jeepers's Avatar
I also run spydertrax on both my jeeps.
I paid about $100/pair.
That works out to $50 per wheel. You can get rims for about $100/wheel. For a couple hundred extra, you could get the rims you'd like (you are running steel rims currently from what I read).
Just a thought...
