Swaying while driving.
Old May 4, 2011 | 07:12 AM
07 JK "bullfrog"'s Avatar
Default Swaying while driving.
Long story short..... I have 2 new 37's in rear and 2 ,85% tread in the front. I just had them balanced and rotated. When I drive my jeep kinda sways back and forth while driving at highway speeds (60+mph). What would cause this? Is it just my tire rotation and will end over time....or do I need an alignment? What should I do?
Old May 4, 2011 | 07:17 AM
wayoflife's Avatar
JK-Forum Founder
swaying as in left to right? and, is it more of a shimming back and forth or, more like being in a small boat on rough seas?
Old May 4, 2011 | 08:10 AM
08yellowx's Avatar
Tire's have to break in, give them a few thousand miles and see if that makes a difference. My 35's did the same thing.
Old May 4, 2011 | 01:37 PM
It's not a shimmy, it's very slow. It will wonder left then wonder right. More gentle but I can notice it right away
Old May 4, 2011 | 02:35 PM
mkjeep's Avatar
Don't drink and drive.
Old May 4, 2011 | 03:15 PM
Hahahahahahaha oh yea that's the problem :beer
Old May 4, 2011 | 03:21 PM
D_engel's Avatar
what PSI? if your pressures are too high, your tires are going to crown and sway a bit
Old May 4, 2011 | 03:26 PM
Um good point:-/ I had my tires at 35 psi and figured that was kinda low(but ran great) . The tire recommends 50psi and that's what I aired them to. I guess that's my problem?
Old May 4, 2011 | 03:42 PM
JKSupamun's Avatar
Default !
whaa?? I run my 37s at 26-27psi ...
Old May 4, 2011 | 04:13 PM
harraid5711's Avatar
Whoa.....no wonder it rides bad. Let some of that air out before they pop like a balloon! The 50psi rating is the MAX that it can safely hold. Put them back down to where you had them. I run between 30-35 for highway driving.
