another tire question
I have a 2007 unlimited x which came with 16 in .A friend has a sahara which came with 18 in rims with 255/70r/18 .He replaced them with after market set,can I put his old 18 s on mine.If so will it effect the speedometor.thanks
JK-Forum Founder
as mentioned, yes, they will fit and depending on what your tire size is now, your speedo may be slightly off as well but, just slightly. question is, do you really want to install a set of 18" wheels? personally, i wouldn't as it is an odd size and one that'll make your future tire selection smaller and more expensive.
thanks my current tire size is 245/75r/16 if it is only off a little i can live with that .I check the speed with my gps today and the speedo is a little under that on the 16 in .As long as the 18 go on all is good .
