Rooftop Tent and other weight creating a lot of rear sway. Need to fix it.
I have a Ulimited JK with a good amount of weight on it (ARB tent, Gobi rack, lod fullwidth rear, highlift, corner armor and 35's).
I have Front and Rear JKS adjustable trackbars, Front Discos, Front Upper Control arms, and had 2.5" terra flex springs and shocks front and rear. I had so much sag in the rear I put 4" terra flex springs in the rear to get the back end back up. Currently the rear sits about 1/2" higher then the front. When I load it for camping it will be close to level, but I might just put some spacers in the front to help level it.
With this setup I have a ton of rear sway and steering delay when changing lanes or going around corners to the point where it feels unstable to drive. I am wondering what the best way to get rid of this is.
Should I preload my rear sway with adjustable rear links by putting them too +15 degrees or so? (currently sitting at about -5 degrees which I think it should be closer to +5)
Should I get a larger rear sway bar?
I could also put my 2.5" springs back in with smaller spacers and some airbags. The 2.5" springs were very compressed from the weight, I had maybe just over an 1" before I hit the bumpstops
