What is my hub diameter???
Old May 6, 2011 | 10:43 AM
fireman9027's Avatar
Default What is my hub diameter???
Looking to get a set of hub centering rings for my Rubicon before I get my wheels. (a bad past experience is making me do this). So I need to know how big the hub is on my 2011 Rubicon 4 door, Thanks.
Old May 6, 2011 | 04:23 PM
D_engel's Avatar
I ordered hub rings when i got my pro comp wheels. Give me some time and see if i can find the specs again
Old May 6, 2011 | 04:29 PM
Battlefrog's Avatar
I went through this a while ago when I was ordering my rims. I called the dealer and asked. I can't remember what the measurement was, but I do know that I didn't need it because my new rims were hub centric... Hop this helps
Old May 6, 2011 | 06:12 PM
D_engel's Avatar
I cant find the order i placed. Im pretty sure the hub flange is 51.1 mm and the average rim bore is 83 mm. This is all from memory so do some more research
Old May 6, 2011 | 06:15 PM
ronjenx's Avatar
I have a front hub in front of me.
What part of it do you want measured?
Old May 6, 2011 | 06:34 PM
Zombie Hunter's Avatar
Hub is 71.5mm
Old May 7, 2011 | 09:07 AM
So I'll need rings that are 83.3, (thats the centerbore on the wheels I want), on the outside and 71.5 on the inside, is that correct??
Old May 8, 2011 | 11:43 PM
Any luck finding the specs??
Old May 9, 2011 | 03:03 PM
Can anyone confirm these numbers?
Old May 9, 2011 | 03:15 PM
fireman9027
That is correct. The closest I can find is 71.5 I.D. X 83.0 O.D.
Made by Gorilla Automotive Products. Part# 83-7150 (set of 4).
