Cut fenders with skill saw?
Old May 8, 2011 | 10:59 AM
ChopN's Avatar
Default Cut fenders with skill saw?
My step dad suggested it when I asked for his jig saw. Its easier to get a straight line but I'm not sure about it. What's the weapon of choice for most?
Old May 8, 2011 | 11:03 AM
interceptor_1972's Avatar
I used a variable speed Jig saw with a fine tooth blade 14tpi used to cut plexiglass and stuff. Jig saw will give you better control when you make the angles or turn the saw - problem with a skill saw or circular saw is that while you will get a straighter line, it'll be hard going around curves and won't give you much control. Just my
tslewisz's Avatar
I used a jig saw.
Old May 8, 2011 | 11:10 AM
08yellowx's Avatar
I did a mild trim on mine with a 4" high speed grinder with a cutoff wheel on it . worked great. Dont even consider the skill saw!
Old May 8, 2011 | 11:14 AM
ChopN's Avatar
Im much more comfortable with using the jig. Really just wanted to show this to my step dad so he didn't interfere lol. Thanks guys. I'll try to get some pics up this afternoon.
Old May 8, 2011 | 11:57 AM
FastCarGuy's Avatar
I've done it several times with a saws-al and get a blade of appropriate length. Lots more power, & easy to control
Old May 8, 2011 | 12:14 PM
Hodge7467's Avatar
I did mine with a 18v Ryobi circ saw. Looks great and very nice cuts.
Old May 8, 2011 | 01:48 PM
Olean NY Jeeper's Avatar
I triimed the front ofmy flairs today and used a small coping saw. Worked great actually.
Old May 8, 2011 | 02:05 PM
shotwell's Avatar
I used a dremel with a guide.
Old May 8, 2011 | 02:17 PM
ChopN's Avatar
Hmm. Didn't think to use my dremel. I gotta get the right bit. I'm gonna try this.
