XD black rockstars vs stock - help please!
Old May 8, 2011 | 08:31 PM
bingote's Avatar
Default XD black rockstars vs stock - help please!
I am decided to buy the XD black rockstars, but i don't know how to choose right.
I have stock wheels with 32s BFG MTs and running RC 1.5" spacers stock Islander, no lift and i think my stock wheels are 17")
Question is, will these wheels add more offset to my tires? (i mean, will add inches outward + the 1.5" spacers?) good for me if jeep stands wider.
Another question is, what numbers should i look for, i mean, there are a LOT of numbers for these wheels, i want to use them with my stock BFG MT 32s (i'll change tires when these need to be changed), so i would like wider wheels than stock but same size so i can use my stock tires.
I see a link like this one (hope is OK to just make it not clickable) and i have NO IDEA what numbers mean and wich one should i pick:
h t t p://www.elites-wholesale.com/Shop/Control/fp/scat/189771/SFV/32431/set_num/1/menu_num/2
Thank you guys.
Old May 8, 2011 | 08:44 PM
wayoflife's Avatar
JK-Forum Founder
so long as the wheels have the same amount of backspacing as your factory wheels (6.25"), they will not change a thing. if they have less, your tires will stick out more.
Old May 8, 2011 | 08:47 PM
TAIL RATED's Avatar
Thank you guys.
you cannot use the RockStars with your stock 17" tires. The RockStars come in both 18" or 20" wheel for the JK..not in 17".
Old May 8, 2011 | 08:52 PM
bingote's Avatar
Thank you man.... How do i translate this to "offset"? Most of the online stores i've seen give offset info more than backspace.
Old May 8, 2011 | 08:54 PM
bingote's Avatar
I was missing that the 17"s are different in design. Thank you. This takes my a step backwards, and make me think about tires then (not planning to look for other wheel option)
Thank you
