TF Leveling Kit to TF 2.5 Coil Lift
Old May 9, 2011 | 06:08 AM
Michiguy's Avatar
Default TF Leveling Kit to TF 2.5 Coil Lift
I am going from a TF Leveling Kit to the TF 2.5" coil lift with shocks today. I noticed the 2.5 kit comes with rear spacers. Are these the same spacers that are in the leveling kit? Those spacers were a mother****** to put on and I am sure they will be just as bad coming off. Thanks in advance.
Old May 9, 2011 | 06:15 AM
wayoflife's Avatar
JK-Forum Founder
they install in the same way if that's what you're asking. a long prybar will help you to remove them.
Old May 9, 2011 | 06:47 AM
HG07JKRubi's Avatar
As WOL says the install should be the same and yes they are different sizes. The leveling kit I believe is 1" and the coil kit comes with a 1/2" spacer simply to retain the coil under full extension.
Old May 9, 2011 | 06:56 AM
coachjamie's Avatar
Would you be interested in selling your leveling kit? I am looking for 1" spacers for front and back.
