Anyone installed a tranny cooler i have a ?
Ok I just got done with installing the cooler , I ran the jeep for a while to check for leaks. My question is do I need to just add enough tranny fluid to make up for what drained out when I cut the lines, or will I need more to compensate for the cooler and lines? I'm i'n town and I'll pick up a quart if I need to
I did mine last weekend and had to add a little over half a quart. May need to add just a touch more. My T oil stick has 2 holes on it for hot measuring. Most guys say to make sure it is halfway between the 2 holes while the engine is running. Mine is just over the first hole. I just drove a 200 mile trip so I will check to make sure it's still good.
