Bump stops
Old May 9, 2011 | 02:09 PM
medic_23387's Avatar
Default Bump stops
Quick question about bump stops. My bump stops that came with my lift BB lift are really long. I have upgraded shocks to fit the lift. Can I shorten the bump stops to get better flex? There is only about 3in between the bump stop and base where it hits.
Old May 9, 2011 | 02:41 PM
DEADGUY11's Avatar
the shorter you make the bumstops the closer u will come to contacting something. Bumpstop the suspension just to the point of contacting, if that means trimming the stop then trim. If it will hit or come close to hitting without trimming the stop then leave it alone.
Old May 9, 2011 | 03:02 PM
wayoflife's Avatar
JK-Forum Founder
your bump stop extensions are designed to help prevent the over compression of your coils. among other things, if you shorten your bump stops, you may get more stuff but, you will run the risk of compressing your coils to the point where they no longer return to their original height.
Old May 9, 2011 | 03:20 PM
Thanks I don't think I will contact anything I have about 3in of lift and flat flares running 35's
Old May 9, 2011 | 03:26 PM
BKGM Jeepers's Avatar
Bumpstops limit uptravel. Longer shocks extend downtravel.
Also, longer shocks have less uptravel because the cans are taller. You can flex your front out and see what limits your travel - your shock, your body (fender) or your bump stop. Then, you can shorten your bumpstop if that's what's limiting your travel.
Old May 9, 2011 | 03:39 PM
Thanks man great advice
Old May 9, 2011 | 05:46 PM
brobbins67's Avatar
In the front, there may be things other than tires that will hit. I smashed the top of my relocated steering stabilizer prior to extending the bump stops.
