Who makes a good tie rod?
Old May 9, 2011 | 04:27 PM
pontiac31's Avatar
Default Who makes a good tie rod?
Did some hard wheeling this weekend and bent, I should say staightened my tie rod out. It is bad enough it hits the front dif when turning about half of the turning radius. So my question is who makes a good replacement? I have the Rock Krawler 3.5" lift with adj arms and front and rear track bars.
Old May 9, 2011 | 04:32 PM
07rubisteve's Avatar
Rock Krawler make a beefy one....I have it, no complaints..
Old May 9, 2011 | 04:33 PM
wayoflifette's Avatar
JK-Forum Founder
Rockkrawler makes one:
http://project-jk.com/jeep-jk-write-...ation-write-up
And Currie makes one:
Old May 9, 2011 | 04:37 PM
Northridge4x4's Avatar
Sponsoring Vendor
Rockkrawler And Currie both are great and I have some of the Steel Rockkrawler's in stock.
David
Old May 9, 2011 | 05:53 PM
PainKiller's Avatar
Currie
Old May 13, 2011 | 07:44 PM
DCMP001's Avatar
Off road only has one. Straight bar that sits 1" higher than stock.
Old May 14, 2011 | 08:07 PM
beadbus's Avatar
Default Can't use these with stock or semi modified lifts
I was told that my 2" lift could not use these unless I added wheel spaces to my stock 2008 Rubicon wheels. Is this true and why?
Old May 15, 2011 | 02:45 AM
blockrockin's Avatar
i have the aluminum rock krawler tie rod .. very beefy ...1 5/8" round
Old May 15, 2011 | 04:09 AM
AFCrawler's Avatar
I have the Rock Krawler, but thought they only made 1 tie rod. I see 3 different Rock Krawler tie rods listed here.
