what should be loosened in front end when putting on a lift?
IV saw some people post that control arms and other things should be loosened while the Jeep is still in the air when installing a lift. What all should be loose and torqued down after the Jeep is put back down on the ground. New to installing a lift and don't want any surprising death wobble or anything crazy when I'm done. Its a DD. Any info on lift install will help thanks!!!! Oh its a 2010 4 door. Putting RC 2.5 springs and shocks
Originally Posted by jvandy50
if you havent done this, do you need to get the jeep back off the ground to do it?
