Wheel/tire weight?
Old May 10, 2011 | 10:18 AM
lowrpmtork's Avatar
Default Wheel/tire weight?
What is the "typical" weight of...
1. Stock 17" wheel and tire
2. Aluminum 17" wheel and 35x12.50 tire
3. Steel 17" wheel and 35x12.50 tire
4. Aluminum 15" wheel and 35x12.50 tire
Old May 10, 2011 | 10:31 AM
ncaa_maniac's Avatar
Sorry, I don't know any wheel weights but 35x12.50 tires are around 70-90 lbs.
Old May 10, 2011 | 10:43 AM
ziggyburke's Avatar
Default Just upgraded
I just upgraded my 2008 Sahara OEM tires with 18" wheels for 35" Duratracs with 17" wheels. The OEMs were 69 lbs and the new tires/ wheels are about 88 lbs.
Old May 10, 2011 | 10:48 AM
bigapplephx's Avatar
Default Wheel/Tire weights
1) 09 Unlimited Rubicon wheel & tire = 75#
2) MT Sidebiter Aluminum Wheel & BFG KM2 35x12.50x17 = 98#
Old May 10, 2011 | 11:05 AM
ShiftySooner's Avatar
A little research here on your part will yield you a bunch of answers. You will find that "typical" here will give you a wide variance, so it may be best to start with what you like, then find out how much it weighs. Most manufacturer sites and online retailers provide statistics like that.
Old May 10, 2011 | 11:34 AM
Jknockers's Avatar
Originally Posted by Corona Doug
Can't help you out on 35" tires... but I checked on my 37" X 13.5" Toyo's and they come in at 97# each without the wheel...
I compared, those are like the heaviest tire out there,, E rated, look killer, but actually belong on 1 ton dually trucks,, I would go MTR K, or a BFG, they're like 20 Lb.s lighter for same size tire
