Rim / Wheel Weight
Old May 10, 2011 | 11:51 AM
cactusjack's Avatar
Default Rim / Wheel Weight
OK, I am gonna try this out... I have seen a couple other people try and start similar threads without much success, but I am gonna give it one more try.
I am trying to make a list of Wheels and their weight.
PLEASE only post wheels and their weights
My hope is that if we can keep this thread dedicated to wheel weight, and then possibly start a new thread dedicated to tire weights with as little B.S. as possible people will be able to use them as a valuable tool when trying to decide what combination to go with...
Old May 10, 2011 | 11:52 AM
cactusjack's Avatar
Here is what I have so far:
Stock 17"- 24lbs
Cragar- Soft 8 17"- 44lbs
Stock- Steel 16"- 24.6lbs
Pro-Comp 7033 16"- 25lbs
Pro-Comp 7033 17"- 28lbs
Method Street 16"- 27lbs
Method Street 17"- 28lbs
Hutchison (BL) 17"- 55lbs
Old Jun 5, 2011 | 07:14 PM
jay01th's Avatar
Trash those wheels, Look at the Pro Comp 1031 thats a 15x8 inch rim that sells for $120 dollars each; this is an Alloy rim weighing only 16 lbs!, add that to your 35 inch KM2 M/T and you will have the lightest setup and get the best MPG around Hands Down.....
