Centerforce dual friction clutch
Old May 10, 2011 | 01:21 PM
Leedsfighting17's Avatar
Default Centerforce dual friction clutch
So i had the original clutch replaced at 11,000 because it would squeek when you depressed the clutch and would chatter terribly when in neutral with the clutch out. replaced it again for the same problem two more times within the 12/12k warranty of the replacement parts. well now i've got 46,000 on the jeep and its doing it again. This time the dealer says that the noise is normal, that they all do it, and they will not be fixing it. While i'm tempted to just sell the jeep as i have other problems as well i really do love it
so my question is those of you who have used it did u have the same problems i have? were they rectified? how would you rate the performance (on/off road)
thanks
