I ordered a dynatrac pro rock 44 axle housing
And I would like to know what my shopping list to fill it is.
I already "know" that I will be going with RCV solid axle cv's and probably eventually an Ox locker and I know I need ring and pinion gears, but I'm not sure what else I need to make my housing a bolted in axle and not a pretty paper weight sitting on my lawn. I know that I can use bits and pieces of my Dana 30 to round out the wheel ends of the axle, but what about the various internals that non mechanics(which I am) don't think about?
Also, are there any differences that I need to know about between a standard pro rock housing and one set up to drop a rubicons internals into?
Thanks for any help.
I see you have a 2 1/2 in lift...if you are thinking of going any bigger I would say that you should make sure and get the housing with the extra camber built in so you dont have any front drive shaft vibration problems like I'm having. I will be ordering either a 44 or 60 housing myself as soon as I save up my pennies.
Unless you already have a rubi front axle, with a functioning locker, get the standard PR housing. I would also choose the Unlimited version of the standard housing, of course.
An OX locker will not fit in a PR44. Do you know what you bought?
Standard housing or Unlimited? BTW- Someone mentioned the Unlimited had camber correction. It's actually caster correction.
Did you order it for a Rubicon locker or a conventional locker?
