rear JKS track bar length??
I am planning on installing a 2.5 lift on my Jeep. I purchased an adjustable JKS rear track bar because I didn't want to deal with the brackets failing, etc. What length should I set the bar at for this height? Thanks
Just curious, why measure the length of the track bar at all? All that matters is that you center up the axle.
Originally Posted by Coley
Start with about a half-inch longer than stock (measuring hole to hole) and see how it looks.
Originally Posted by b5rider
Sounds good. I'll run a plumb line and mark the axles and frame before I lift it to have a reference point
This job is most easily done with two people--one to put the trackbar on, the other to push the vehicle to either side to help line things up. Some folks have used a ratcheting tiedown to replace that second person and allow the vehicle to be pulled one way or the other.
Good luck!
