did i get my tranny fluid to full?
Old May 11, 2011 | 12:26 PM
greenenvey's Avatar
Default did i get my tranny fluid to full?
i added extra tranny fluid after installing cooler, i filled and checked it several times checking the level and it looked fine. I just got home and checked again and its a tiny bit above the top hot hole. Ive read its sapose to be between the two hot oil holes? should i remove some?
Old May 11, 2011 | 12:50 PM
greenenvey's Avatar
Originally Posted by GON WHLN
It should read (if hot) up to the "hot level" line. I personally would remove the extra. Alittle less is better in this situation.
this time i checked it in neutral like the dipstick says to do and it was between the 2 tops holes like it shoud be so mabey its fine i hope. Others say to check it in park and it shows too full like that!!
Old May 11, 2011 | 02:24 PM
ronjenx's Avatar
The dipstick says one way, the owner's manual says the other.
I have tried it in park and neutral, and it was pretty colse to the same. I guess it only matters if one is at the limit.
