Painting ARB Differential Covers
I am looking to paint my ARB Covers black. How should I go about this?
Should I put Bedliner on it?
Is Bedliner easily chipped?
should I put on a primer?
As u cab see I have pretty much no clue, please help.........
Originally Posted by jsuell
I just panted mine with a rattle can over a year ago now holding up fine
Also did u keep the cover on when u did it or take it off?
Originally Posted by Birdog3
I'm going 2 just scuff mine and paint them stay away from lots of coats and beadliner it will hold in alot of heat and the cover is maid to disapate heat. hope that helps
I have some puff cans maid up with my paint code so i can paint odds and ends. im going it sand blast the red off the paint i think they may be powder coated i have'nt had time to mess with them. you can still use 200-320 grit sand paper you just want to give the paint something to bite to.
