Need 71.5 x 83.82 hub centric rings.
Old May 11, 2011 | 06:18 PM
ArkJK's Avatar
Default Need 71.5 x 83.82 hub centric rings.
Anyone know where I can get these?? I've seen rings for $9.99 for 4 and $45 for 4 so I'd like to keep it on the cheaper end if possible. Just having a hard time finding them in this size seems like. Any help would be appreciated. Thanks!!!
Old May 12, 2011 | 05:56 AM
ArkJK's Avatar
So I can't find them anywhere for under $55 for the size I need. Any suggestions on where to look? How come most are around $10 but the size I need is $55??!!! They must know its for a jeep therefore they made it expensive like all other jeep accessories.
Old May 12, 2011 | 06:12 AM
Harbourone's Avatar
Why do you need the rings? Lots of people, myself included, run lug centric wheels and have never had an issue.
Old May 12, 2011 | 06:25 AM
ArkJK's Avatar
Pretty much because I'm having the same type of problem as the OP here. Although mine isn't as bad from how he explains his problem.
https://www.jk-forum.com/forums/show...ghlight=cragar
So anyone know where to get them? I really don't want to get into a discussion as to if I do or do not need them. haha
Old May 12, 2011 | 09:21 AM
ArkJK's Avatar
OK found some for $11. Thanks for the help gang.
Old Aug 29, 2011 | 12:46 PM
metro's Avatar
Hey where did you end up getting your hub centric rings?
Thanks.
Old Jun 18, 2012 | 05:36 AM
ArkJK's Avatar
Just wanted to post this because I've received a couple PMs about where I got mine. I honestly can't remember, but google is your friend and with just a little searching, you can find some. here's 4 for $55.99 so that's only $13.99 each or something like that. Just scroll down and they have the size needed for the JK.
Wheel Hub Centric Rings - buy wheel hub rings online from 1010tires.com
