Normal to have to retighten lugs quite a bit?
I know the general rule of thumb is to recheck lugs after 250 and then 500 miles of putting on new wheels, but wasn't sure if it was normal to continue to have to retighten then beyond that point? I've had aftermarket wheels in the past and dont remember them requiring such. Every time I've checked these I've had at least 5 lugs that I was able to tighten up quite a bit. Should I be concerned about this?
When I say tighten up, its not like they are loose, but I am able to tighten them another 1/2 turn or so.
Do you use a torque wrench? I check mine every so often. Sometimes a few may be a little off. I just re tighten to proper torque. I run heavy 37's though. If the same exact ones keep doing it, change the lugnuts out, see what happens and or just change the studs.
Definately check and retighten after wheelin.
I've never used a torque wrench on mine, but when I check them a few usually go about a half turn more. I clean and grease the lugs whenever I have the wheels off though, so maybe that is contributing. Still stock wheels too.
Wheel lugs and nuts should not be greased. They depend on the thread's and mating surface's friction to stay tight. The torque speck is based on clean, dry threads.
You're probably right, I just think it helps them last longer, and makes them easier to take off (at least in my head).
Your impact wrench is probably 200-600, right?
I wondered if this might be an instance where the wheels not being hubcentric was influencing the lugs staying tight. Is that a possibility?
