Help with gas mileage??
Old May 12, 2011 | 07:21 PM
kenbren1313's Avatar
Default Help with gas mileage??
I have a 2011 Sahara Unlimited with 35" Terra Grapplers and a 4.5" BDS lift. I installed a Volant Powercore CAI and am getting 12.5 MPG. I am running stock gears but still this seems extremely low....I see posts of people saying they are getting 18-20 with similar set ups......HELP????
Any suggestions and or feedback would be apprecaited!!
Old May 12, 2011 | 07:26 PM
Cdyspeed's Avatar
Hey I posted on ur other post, as soon as these company's come out with a tuner for the 2011's you should invest in one as well as re-gear. I had 3.21's and I was getting about 14.5 mpg with 35's. Do u have a manual or auto?
Old May 12, 2011 | 07:28 PM
Cdyspeed's Avatar
I also forgot to mention you are getting better mpg then u think bc of everything being off your mpg, odometer, and speedo
Old May 12, 2011 | 11:50 PM
Dale36's Avatar
Has the speedometer and odometer been recalibrated?
Old May 12, 2011 | 11:52 PM
jtjk's Avatar
Gas millage on the jks seems to vary strongly between jeeps - even if the are running similar setups, its very much a crap shoot in my opinion.
the re gear i think is your best bet for better millage
Old May 13, 2011 | 05:15 AM
Thanks for your replies! I have a Auto and have not used a tuner to recal the odometer. I have tried the fill and run to empty and fill again....then divided miles/gallons. That is how I came up with 12.5.
Just seems really low to me....I am getting about 250 per tank???
Old May 13, 2011 | 05:26 AM
Hook-Em's Avatar
If you haven't recalibrated your speedo, then the number of miles displayed on your odo will be low. When I put my 315/70r17's (35's) on I verified my speedo againts mile markers and a GPS. Both showed 10% error. (E.g. When driving 60 mph on speedo, I was actually driving 66 mph)
You will have to get a tuner, recal to your tire height. Then and only then can you begin to worry about you fuel efficiency.
With your setup I wouldn't expect you to get more than 16-18 mpg. Maybe 20 tops if you drive very conservatively.
Good luck.
