ACE Rock rails
Old May 13, 2011 | 08:22 AM
sklrng's Avatar
Default ACE Rock rails
Just installed my rock rails by ACE. The install was very easy 2 bolts on each side and just had to grind down the washers. They seem very sturdy when I was jumping on them. It wont be a while until I get to the test them out on the trail Click image for larger version
Old May 13, 2011 | 08:37 AM
JkFam's Avatar
Originally Posted by sklrng
Just installed my rock rails by ACE. The install was very easy 2 bolts on each side and just had to grind down the washers. They seem very sturdy when I was jumping on them. It wont be a while until I get to the test them out on the trail Attachment 159910
Looks good and based on what I've heard these seem to be very well made. I have the rubi rails but would like to extra protection these could provide and it would be nice having a step also. Post back here after you get to use them on the trail
Old May 13, 2011 | 08:58 AM
TURTLECON's Avatar
Just installed my rock rails by ACE. The install was very easy 2 bolts on each side and just had to grind down the washers. They seem very sturdy when I was jumping on them. It wont be a while until I get to the test them out on the trail <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=159910"/>
When they say you need to "grind down the washers" which ones exactly? Can you snap a pic of where on the JK this is referencing? I'm about to pull the trigger on ordering these, but not sure I have any tools to complete this step.
Old May 13, 2011 | 09:14 AM
TXJimmy's Avatar
The body mount bolts under the rocker panel area have some big thick washers that have to have flats ground on to them so they will sit flat in the pockets of the mounting arms for the sliders.
I used my bench grinder, but an angle grinder would work just as well if you have a vise to hold them in.
I highly recommend them! Good price, great quality.
Old May 13, 2011 | 10:51 AM
TURTLECON's Avatar
I'm still not 100% clear on this. Can u take a pic? Instead of grinding, couldn't I just buy new washers to fit? And don't the ACE sliders mount to different points than the Rubi rails?
Old May 13, 2011 | 04:51 PM
IDiggs9's Avatar
Default Ace
Nice rails , good quality , fair price , easy install ! I have the ones that fit with the Rubi rails . Fit nicely. And look good together . Actually met the owner in Daytona yesterday.
Old May 13, 2011 | 04:53 PM
JkFam's Avatar
do they weld on to the rubi rails? how do they mount on together?
Old May 13, 2011 | 05:02 PM
IDiggs9's Avatar
Default Ace
Adjust the rubi rails as high and as close to the body as possible . Then mount the Ace rails as instructed. Fit good together ,still both pieces are separate pieces. No welding. I will get pics on tomorrow.
Old May 13, 2011 | 06:21 PM
Foam-it's Avatar
Put a set on our 2011 Rubicon two weeks ago. Love them! Very well built.
Old May 13, 2011 | 08:43 PM
TURTLECON's Avatar
Yeah I just got Rubi rails off craigslist a couple weeks ago & are looking at ACE specifically cause they fit with the rails on... plus they look badass
