rubbing on the front fenders under articulation at full turn.
Just installed my 37's tonight. Flexed up a bit to see if I was rubbing on the pinch seam, and I clear it no problem. Ill rub on the rear bumper, but I clear the pinch seam. Couldn't get the last 2.5" of flex out of the rear, but it shouldn't come forward.
When I was turning around I heard some brutal noise. Turns out that under medium articulation (not disco'ed), and at full turn, the front tires are rubbing the rear of the front wheel opening. I was going to just cut it out, but was wondering what options I had.
Is there a write up for steering stop adjustment? I have a set of 1" spaces I could add to the front as well. Would this help?
I have a net bs of 2.27" with my wheels and spacers combined. Tires are 37x14.5. Running an ome hd lift with 1" spacers on all 4 corners.
http://project-jk.com/jeep-jk-write-...top-adjustment
There ya go. Let's see the pics!
sent from HTC Thunderbolt via tapatalk.
Adjust your steering stops for the front.
For the rear there is a write up on making a factory bumper a stubby. Or buy a stubby rear.
I would try those 2 things first.
As you get more room then you can check your bumpstops and fender clearance.
CHOP CHOP CHOP
Good looking rig. Which lift are you running?
CHOP CHOP CHOP
Originally Posted by dinojeep
Is that a mud flap?
My lift is ome hd coils, 1" tf coil spacer, ome lt shocks, extended brake lines, jks tracbars. Stock arms.
Just found a front wheel bearing has a quarter in of play. Explains the wandering...
Originally Posted by Harbourone
Yea it a mudflap. Came on the factory bumper when I bought the jeep. Just sold my steel rear bumper so I threw the stocker back on.
Originally Posted by 07 JK "bullfrog"
Get a bigger lift haha but the cheaper way would be to get a new rear bumper. If you really want to get a full flex with no rubbing go with some bump stops or bigger lift.
