JKS front track bar brace
Old May 13, 2011 | 07:58 PM
inspect-a-home's Avatar
Default JKS front track bar brace
Item Number: OGS161
Who's got the best deal on these?
Also gettin' rid of my skyjacker front and rear trackbar braces, coils, shocks, sway links for front.
Old May 13, 2011 | 08:08 PM
Grognard's Avatar
I went with an JKS OGS162 brace because it also relocated the steering stabilizer. Northridge has a great deal on it paired up with a TF SS
http://www.northridge4x4.com/proddet...KS-OGS162COMBO
Pretty good deal
Old May 14, 2011 | 05:53 PM
the JKS front track bar brace does not give additional height, would I be alright with just the JKS adjustable front track bar? Which route did you guys go with a 4" lift?
I'd rather have a brace which you can bolt and or weld later.
Old May 14, 2011 | 07:15 PM
Castalone's Avatar
That 161 part from jks rocks! You can relocate the stabilizer, and put your trackbar in a couple locations. It also gussets a few points on the axle. O ya, looks cool too!
Old May 14, 2011 | 07:19 PM
Castalone's Avatar
I had just an adjustable trackbar which is ok. The bump steer sucked. I did the draglink flip and jks bracket HUGE difference!
Old May 14, 2011 | 07:27 PM
That looks great! Did you have to purchase a relocation bracket for the SS? And it looks like u welded the SS to ur tie rod? Just wondering without the lift height on that bracket the geometry with my drop pitman arm would result.
Old May 14, 2011 | 07:44 PM
Castalone's Avatar
You will get different opinions but, with 4 inch I think either a drop pitman ARM or a draglink flip will work... I think and have seen that the drop pitman ARM puts to much stress on a already weak steering box shaft, I've seen it brake.
